Z AXIS BLOCKED in one direction
Re: Z AXIS BLOCKED in one direction
Then plug Z motors into X/Y motor's slot on the board to see how Z motors go.
Pierfrancesco
Post by Pierfrancesco »
Yes... In X,Y slots Z motors works fine... Separatly but in both direction
Pierfrancesco
I think that the board is defected, how Can I get another One ?
Take some clear photos of your board's back and front,i wanna see if there is a bad soldering at the "DIR" pin of Z axis.
Pierfrancesco
Pierfrancesco wrote:Image
You can try soldering this spot in the picture again if you have a tool.
PS.Did you try reflashing the firmware for Pro B?
Pierfrancesco
I will try to solder... Yes, I reflashed firmware many times
Pierfrancesco
Nothing happened, always the same... :(
Try the new board when it arrives,and update this post plz.
Pierfrancesco
Thank you man :)
