geeetech rostock delta 301 not printing...
chiffa
Post by chiffa »
Hello. I assembled rostock delta 301, but have some problem:
1. When I click HOME button in Repetier-host the parameters becoming x=0 y=0 z=228, but in instruction wrote that z must be 220. is it fundamentally? there is so, how to fix this?...
2. When I send something to print extruder rests in building platform and PLA is not gone. Respectively, nothing is printed.... When extruder is gone up PLA is drips down...
How i understand 1 and 2 problem linked...
3. What is the printing radius? In Repetier-host I set 100 (as was in instruction), but the extruder is not set on center....
help to understand what is the problems. Thanks!
Slacker
Re: geeetech rostock delta 301 not printing...
Post by Slacker »
I think 1 and 2 are related. The extruder must be at a paper width above the platform. If its too close/touching it can block up the print head. It seems strange that it is not using Z=0 for the home position, but I have a different printer.
I dont know if it will help, but have you looked in Slic3r -> Configuration -> Printer Settings -> Z offset? Dont forget to press save if you make a change.
chiffa
Post by chiffa »
Extruder is stop uper on building platform, but PLA not come from nozzle and nothing print...... when extruder go up (home button) PLA is drips down from nozzle...
chiffa
Post by chiffa »
wherein the moving coil with plastic
Lami René
Post by Lami René »
Bonjour,
You will find the original text translated into English following this original French text.
Est-ce qu’aujourd'hui vous réussissez de belles impressions avec votre imprimante delta Geeetech Rostock 301 (M301) ?
Pas moi, je l'ai acheté le 24 septembre 2016 et reçu le 27 octobre 2016, mais aucune impression à ce jour, que des pièces défectueuses ou des erreurs de conception dans le choix des pièces ! Je suis en attente de pièces de remplacements.
Si comme moi vous n'avez pas de belles impressions 3D, voir des pistes de solution dans le sujet suivant :
http://www.geeetech.com/forum/viewtopic ... 27&t=18578
Cordialement,
L'ami René
Do you make today beautiful prints with your Geeetech Rostock 301 (M301) delta printer?
Not me, I bought it on September 24, 2016 and received on October 27, 2016, but no impression to date, that defective parts or design errors in the choice of parts! I'm waiting for replacement parts.
If like me you do not have beautiful 3D impressions, see solution tracks in the following subject:
Cordially,
Friend René
One for all and all for one !
