Z axis problem
Z axis problem
I have a problem with z axis. When i tight bearing holders top plates they wrench and jam the z axis. when i loose the top plates bolts it moves well...
- hdhdh.jpg (339.55 KiB) Viewed 11818 times
Re: Z axis problem
You can disassemble this part,then reinstall it to check it's a screw mounting problem or some issues on the hardware.
Re: Z axis problem
Same problem both sides. I think that acrylic parts causes it.
Re: Z axis problem
You can check it with the manual carefully,or maybe you missed some mounting details.
Re: Z axis problem
Mounted just like manual says.
Re: Z axis problem
Those z axis bearing holders are very bad design... Always stuck the z axis!!
