Bonjour, quand j' appuie sur home pour l' axe y, le lit ne bouge pas.
Pourriez vous m' aider svp ?
Merci
Goodmorning, when I push home for y, y dont move.
I already need to change y and x motor direction and
Endstop x & y too.
But when I test x endstop, the motor wont stop and continue also if endstop is pushed by x axis.
Can you help me please ?
Wath is the line I need to change if only the y home is incorrect ?
Thanks you
Y home dont want move
Re: Y home dont want move
Did you have every endstop connected to the right port on the board(X_min,Y_min,Z_min slot)?
If you did,could you move the two motors in the menu "Prepare->Move axis"?
