I like to install a fan for Filament cooling. My Printer has a GT2560 Rev B board. Unfortunately there is no circuit diagram for this board available. There is a connector on the printhead board available for an additional fan. But I´m not able to find out how to use it. There are some informations in this Forum, but they don´t answer my questions.
Can you please send me a circuit diagram for the board? Or can you tell me how to use the additional connector for the Filament cooling fan?
best regards
Peter
						Questions to MeCreator2
Re: Questions to MeCreator2
Hi Peter,
to connect an additional fan to the printhead board you need an 3-pin JST-PH connector. If you have plugged the connector in the board the pin on the top is + (red) and the middle pin is - (black).
After I updated the firmware to the latest version the fan is working without a problem.
You can find the firmware here: http://www.geeetech.com/forum/viewtopic.php?t=17046
I hope this helps.
Regards,
Christian
I hope this helps.
Regards,
Christian
