Simplify3d Settings
Simplify3d Settings
Hi all
Having problems with Simplify3d, When I print from SD card the printer homes then goes straight to print without pre heating the nozzle and bed, here are the settings I got from Prusa's forum
;Sliced at: {day} {date} {time}
;Basic settings: Layer height: {layer_height} Walls: {wall_thickness} Fill: {fill_density}
;Print time: {print_time}
;Filament used: {filament_amount}m {filament_weight}g
;Filament cost: {filament_cost}
;M190 S{print_bed_temperature} ;Uncomment to add your own bed temperature line
;M109 S{print_temperature} ;Uncomment to add your own temperature line
G21 ;metric values
G90 ;absolute positioning
M82 ;set extruder to absolute mode
G28 X0 Y0 ;move X/Y to min endstops
G28 Z0 ;move Z to min endstops
M117 Auto Calibration... ;Put printing message on LCD screen
G29 ;auto bed level
G1 Z15.0 F{travel_speed} ;move the hotend up 15mm
G1 X0 Y0 Z0.4 F5000
G92 E0 ;zero the extruded length
G1 F200 E30 ;extrude 30mm of feed stock
G92 E0 ;zero the extruded length again
G1 X50 Y0 Z0.1 F2000 ;
G1 F{travel_speed} ;
M117 Printing... ;Put printing message on LCD screen
Don't have a clue on the G-code settings.
What should I alter and do I need to alter any settings in Simplify3d?
G21 ;metric values
G29 ;auto bed level
G1 X0 Y0 Z0.4 F5000
Re: Simplify3d Settings
Does someone know how to fix this?
Been at this for 4 days and cannot figure it out.
Help please
Help please
you need to set the tool 0 and tool 1 of the two extruder
and the temp of both of then to tool 0
try this
maybe its ill fit ( sorry dont rember)
printing 3D with M201 Geeetech
HI,
where I find the Simplify3d Settings for Mac Ios?
Thank you
Thank you
Does anyone have the FFF Profile to simplify 3D for Geeetech i3 Pro C for two-color printing?
Thank you
Thank you
Here is what I use on my Pro C for two color printing. It assumes offsets are set in firmware.
- Two Color Cool Bed.zip
- (2.97 KiB) Downloaded 1378 times
Thanks Cosmith,
I hope so, otherwise what should I set?
I put your setting, but the press of left corner. If I change the printing does not start.
What should I do to change EPR from the press at the center of the dish?
In firmware do I need to change this, but I think it's not fair
#define ENDSTOPS_ONLY_FOR_HOMING // If defined the endstops will only be used for homing
