LCD 12864 with GT2560
Raisa
Re: LCD 12864 with GT2560
Post by Raisa »
PS: rmrodriges ... this is also appearently your Problem with the Display as well, please check it yourself before modifying it with your multimeter... :)
Hopefully this helps you!
rmrodrigues
Post by rmrodrigues »
Yep. it should be the same problem because the vendor is the same.
Did you change the connectors position? Could you post some photos please?
Many thanks.
RMRodrigues.
Raisa
Post by Raisa »
Hello again,
Yes, for the LCD12864 from bigtree-tech the connectors should have been mounted 180° turned, but here I have a modification.
All you have to do is just to turn the cable connectors 180°.
Still, please do the checks with a multi meter before retrying, I take no responsibility if it is not working for everyone !!
Be warned and measure first before damaging your equipment . :)
I just know it worked out for me and with the bigtree-tech LCD12864...
In the attachment is a small image, which might help...
Best regards,
Raisa
Modification... do at your own risk !
rmrodrigues
Hi there,
As Raisa suggested me, I've turned the connector 180 degress and it's working fine now.
Many thanks Raisa.
Cheers.
RMRodrigues.
Raisa
Post by Raisa »
has been a pleasure to help ;)
shiva
Post by shiva »
Hi Raisa
i am getting same problem.Please let me know should i cut all the wires and rotate 180digree connection ? or cut and swap frist pin and last pin?
thanks
Shiva
shiva
Post by shiva »
Thanks Raisa,
I have done it,Started working
Scooby
Post by Scooby »
Hi All
I am having the same problem a blank screen and a red led number D8 by the heater 2 connection on my GT2560. I know it is an old thread but if any one can help I really do need it,,, ;)
Scooby wrote:Hi All
Could you post some pictures showing the details?
TheDuke99
Post by TheDuke99 »
Thanks to everyone who cleared up the reversed pins issue, solved my issue with the Big Tree board.
Thanks!
Mike
Chattanooga, TN
