Hello everyone.
I started to build ultimaker clone with gt2560, and Iam almost done but...
My friend help me on start, but now i have to do it myself - the firmware thing. Iam totally amateur.
1. First thing is on firmware i think, because i have heatbed mk3 12v and i do not see it on LCD i have only nozzle 1 and nozzle2. I cant even check if bed works.
2. I have two head termistor, when I connect 1st with 3 wires(red one should go to 5v) the temp on lcd is 270...on start, when I disconnect red one from the 5v temp is 130... i dont know what is this. But second termistor works only under second termistor slot for nozzle2...
I will be thankful if somebody explain it to me step by step, what i should do.
Some screens:
https://drive.google.com/file/d/0B-zmof ... sp=sharing
GT2560 Rev A - Ultimaker Clone firmware problem(amateur)
Re: GT2560 Rev A - Ultimaker Clone firmware problem(amateur)
Maybe you can try the firmware for I3 ProB in this post:
Ok, now i found bultimaker for firmware creator to my printer, everything working except extruder motor:(
But earlier extruder motor with different firmware sensor configuration works...
