I got a problem with the homing of my Rostock 301.
One bearing activates the corresponding endstop and moves a bit down as it should.
The second stops before it hits the endstop and the third keeps running upwards, pressing against the endstop.
This behavior is independent of the axes.
Does anybody know a solution for this problem or has a suggestion? I tried configuring the options for endstops, axes max min, etc. in any possible way but I can't find the cause of the problem or it's solution..
						Rostock 301 Endstop problem
Re: Rostock 301 Endstop problem
Did you have all the endstops correctly connected the corresponding connector(X_min-X endstop,etc.)
Then check if the cables of motors on 3 axes has good connections,rewire them if necessary.
And you can test if your endstops work normally by pushing them down(the motors will stop moving) when auto home.
Hello Midnightcrash,
Bonjour Midnightcrash,
Vous auriez une vidéo montrant le problème ?
Cordialement,
L'ami René
Do you have a video showing the problem?
Cordially,
Friend René
Cordialement,
L'ami René
Cordially,
Friend René
One for all and all for one !
maybe you can check the endstops by using a multimeter.
				Midnightcrash
Thank you for your replies. I managed to find and fix the problem by testing the endstops by hand while homing. The X-endstop and the Y-endstop crosstalked and that's the reason for the strange behaviour.  I rewired and isolated them again, now everything is working.
