How to start Geeetech I3 Pro C in Repetier-Host
zhangxueyou
Post by zhangxueyou »
Open Repetier-Host (Download link: http://www.repetier.com/download-now/), Access "Printer settings":
Set correct baud rate and serial port:
choose baud rate and serial port.png (23.6 KiB) Viewed 42854 times
Set amount of extruder as 2, and set correct nozzle diameter:
Then you can control both extruders on Repetier-Host (Note:The extruder can not move unless the temperature is more than 180 degrees):
Slicer setting:
To have a good 3D item,you need to have a good slicer setting, and distribute jobs for 2 extruders:
Click "configuration" to access slicer setting:
For more details of sclicer setting, you can download the attachment to refer:
slicer settings for I3C.zip
(740.38 KiB) Downloaded 1536 times
lobbo1979
Re: How to start Geeetech I3 Pro C in Repetier-Host
Post by lobbo1979 »
Thanks for sharing.
https://3dprinterchat.com
AbeFM
Post by AbeFM »
Could you save the slicer settings as a file that can be loaded instead of as a series of photos?
Did you notice this?
(740.38 KiB) Downloaded 169 times
AbeFM
Post by AbeFM »
AbeFM wrote:Could you save the slicer settings as a file that can be loaded instead of as a series of photos?
Did you notice this part? :-)
I mean a file with the settings which we can load directly.
Galas
Post by Galas »
Thanks for the information. And can I combine several printers in one program. For example, I will have one template and the same settings but two printers. Is it possible?
imrozahmad
Post by imrozahmad »
How to Activate Showtime Anytime? Install Showtime Anytime, the Showtime Everytime App to the Android Smart TV. * The app can be downloaded on the official website
Showtimeanytime/activate
play.google.com/redeem
lowe's gift card balance
primevideo/mytv
amazon.com/mytv
amazon.com/redeem
amazon.com/code
amazon.com/mytv
primevideo/mytv
amazon.com/code
amazon.com/redeem check balance
Appstore.com/redeem
LucyKelly
Post by LucyKelly »
Thank you for providing this information. Is it possible to combine multiple printers into a single program? I want to print out the images of the drift hunters game, a speed racing game. Is it possible?
