SD card problem
SD card problem
Hy!
I buy one of your printer prusa i3 pro B2 from ebay.de
It works more than good, i realy did not expected as much from it.
But there is one problem it works only online from computer, if i just pust the button on lcd the printer freeze and can't eaven connect with the PC. Even if i pust one or other reset button not helped, lcd just show two line on lcd.
Only solution is that i disconect the SD flat cable, than i can reset it.
I try to upload new FW for a few times but nothing, i checked al the circuit, all the connector and cable, but can't find the problem.
Also try many different SD card with different format...
What can i do to print without PC?
Thanks Tine
Thanks Tine
Re: SD card problem
Forget to tell also don,t work the front reset button on LCD (under the knob)
Re: SD card problem
Did you try other ports on your PC or change another USB cable?
Re: SD card problem
bang wrote:Did you try other ports on your PC or change another USB cable?
Why? I said that works great with pc and usb connection, there is problem with sdcard or offline mode, if i do not heave connected usb cable at all and just push the knob and try to go down it freeze and can't be reset.
Re: SD card problem
OK,i think i mistook it...
Did you try heating up or moving motors?
Re: SD card problem
I can't try because printer freeze that moment i push the knob to got into menu.bang wrote:OK,i think i mistook it...
Re: SD card problem
Problem solved.
I start looking the picture of other GT2560 controller board on internet and find my problem pretty fast.
Problem:
solved:
Problem:
solved:
Re: SD card problem
So the socket direction is the exact problem?
Re: SD card problem
Yes, some guy solder it on wrong way, i don't want to desolder it and solder again, so just cut another hole on other side and turn the connector for 180 degree, it works now, thanks
Tine
Tine
Re: SD card problem
Awesome
