hi
Today i brought BL Touch sensor for My I3 pro X.I read wiki and somany topics related sensor.
But my problem is My board have only 2 pin in Z maximum.how to make it 3 pin or any other place possiable to place 3 pin?
Please explain me
GT 2560 3pin modification for BL touch sensor
Re: GT 2560 3pin modification for BL touch sensor
Hi,Shiva
Have a look at this picture,and refer to the manual of 3Dtouch:
this picture iSeen in wiki,But i get confuse where i have to solder 3rd pin.I guess next to 2nd pin there is place like small Dot is there.
Also one more doubt,I am using repetier-Host Cura.So please let me knowwhere I have to hek G28 and G29 command in Cura?
1.You need solder 3-pin connector on "Z_max" position(you can see the printed chars on the back of the board).
2.I didn't find the entrance to type in the Gcodes in Cura,and i'm afraid you have to use Repetier Host...
I connected every thing as per instruction, updated frimwere .If I give print 3d touch sensor not blinking or not sensing .But all printers axis working.Please tell me what is problem?
Did you fix it?I guess it is the firmware issue.
I fixed it,the third pin not solder proper.i re solder that.now its working.thanks
If you, as I do, have a GT2560 Rev.A and do not get comfortable soldering onto the GT2560, you can get the BLTouch to run by following this workaround:
1) Connect the black and white wires to Z-min as explained on the Geeetech wiki
2) Connect the brown and orange wires to two-pins socket where you should solder the three pins that is, to the right of the Z-min connector: the brown on the bottom pin and the orange on the upper pin (looking at the board with the USB connector facing downwards)
3) Connect the red wire to the available stepper socket: on the blue strip, second pinhole starting from below.
See attached picture.
That is what it takes on the hardware side. Now on the software side you have to activate "#define SERVO0_PIN 32". See Geeetech wiki for 3DTouch.
I have attached the Marlin version I adapted based on based on NiklasO (see NiklasOlofsson in GitHub) configuration I use in my printer for your reference. I have successfully compiled it with Arduino IDE 1.8.1.
- Marlin.zip
- (876.54 KiB) Downloaded 1306 times
- GT2560.jpg (152.54 KiB) Viewed 22306 times
