Easy Print installation
DoubleK
Post by DoubleK »
Have installed Easy Print but the program will not slice my stl file. Also can not see the complete window in setting mode.
Re: Easy Print installation
You can click on "Settings" then enter "Custom" mode:
DoubleK
Post by DoubleK »
Here a sample, that the buttons below i can not see. Slicer have no function in my programm.
Imagehttps://postimage.org/index.php?lang=german
idom
Post by idom »
The software finds the printer and gives a "connected status" , other than that it does not do anything else. Same error reported in other posts.
bang
Post by bang »
DoubleK wrote:Here a sample, that the buttons below i can not see. Slicer have no function in my programm.
Oops,so you didn't have a complete window as William's?
For slicer issue,you can uninstall the software then reinstall it to other disks to take a look.
bang
Post by bang »
idom wrote:The software finds the printer and gives a "connected status" , other than that it does not do anything else. Same error reported in other posts.
Did you check if you have selected the right printer?
And you can try flashing firmware via "Help->Update firmware" then reconnect it to see if there is a difference.
DoubleK
Post by DoubleK »
Can not select the right printer. He wants always Me Creator and i have I3 Pro X. He want only Update Me Creator. Can not set the com port also.
idom
Post by idom »
I did tried to update firmware but it comes out with a "failed update", I have selected the right printer as well, many times.
DoubleK
Post by DoubleK »
Have installed the Programm to another partition of hard disc, but see the incomplete window also.
bang
Post by bang »
You selected the right printer,and did you select the right COM port(maybe there are some other USB devices on your computer)?
