GT 2560 Rev a+
Jay Low
GT 2560 Rev a+
Post by Jay Low »
Hello everybody,
I am trying to connect an inductive sensor on my GT2560 rev a + card with the "servo" connector.
Can you tell me how?
What is the signal to receive "S"? And how to activate it in the firmware?
Thanks a lot for your help.
JL
bang
Re: GT 2560 Rev a+
Post by bang »
Did you notice the 3-pin connector?
The "S" pin is a servo pin and connected to the pin11 of the mainchip.
Jay Low
Re: GT 2560 Rev a+
Post by Jay Low »
Yes, it's the 3 pin connector.
it is possible to use it for connect a inductive sensor ? and if yes, how ?
i72rugoa
Re: GT 2560 Rev a+
Post by i72rugoa »
Good morning,
I installed the wiring as indicated in the photo, I made the changes in the firmware and it does not work. Sending GCODE manual code and no response.
What could be the problem??
i72rugoa
Re: GT 2560 Rev a+
Post by i72rugoa »
I have done many tests and the problem is that S connection is not enabled. How could one enable ??? Is there a bridge on the GT2560 that enables it? Or maybe the firmware ??
bang
Re: GT 2560 Rev a+
Post by bang »
@i72rugoa
Did you modify the code in "pins.h" correctly?Maybe you can attach this file.
COSA
Re: GT 2560 Rev a+
Post by COSA »
Hi did you fixed I having the same issue. Thanks
Kristoffer
Re: GT 2560 Rev a+
Post by Kristoffer »
same issues here also
Aircraft Monkey
Re: GT 2560 Rev a+
Post by Aircraft Monkey »
I have the same issue and have tried all firmware from 1.1.3 to 1.1.6 and the 3D Touch will not engage at all other than when printer is powered up. I have an accual programmer that will help if I can get the pin mapping of this board. Anyone have this?
Re: GT 2560 Rev a+
Maybe it can help you?
