Download easy print
pamato
Re: Download easy print
Post by pamato »
What happened to the download? The file is missing.
bang
Post by bang »
pamato wrote:What happened to the download? The file is missing.
The downloading link is working fine...
Lami René
Post by Lami René »
Hello bang,
Bonjour bang,
Oui, Admin a effacé son dernier message qui incluait un hyperlien qui ne fonctionnait pas et il ne reste maintenant qu'un lien qui fonctionne dans le premier texte de présent sujet écrit par Admin. Je présume que ce lien donne accès à la dernière version courante du logiciel Easy-Print, car le lien est sans numéro de version.
Cordialement,
L'ami René
Hello bang,
Yes, Admin deleted his last post that included a hyperlink that did not work and now there is only one link that works in the first text of this topic written by Admin. I assume that this link gives access to the latest version of the Easy-Print software because the link is without a version number.
Cordially,
The friend René
One for all and all for one !
Stemiles
Post by Stemiles »
Ifi you want connect your printer modify the file:
C:\Program Files (x86)\Geeetech\Easy Print\printer.ini
on the top:
[common]
serial_port=COMXXX Set your com port
machine_list=D200;M201;Rostock301;PI3;M201_GT2560;MeCreator;
machine_type=XXXXX set your printer name
machine_count=7
admin=0
slice_config=standard
Version=V1.0.15 Beta
I hope that for you now is ok
I'm waitin some update about low buttons not visible!
idom
Post by idom »
Ok once Administrator privileges are granted it does connect but not more than that, I cant update firmware, it just stays "waiting.." cant control neither. Keep showing error
yuredd
Post by yuredd »
Hi!
I like your software and I'd like to give a hand (I'm a developer), will you upload the sources on github?
MikaëlV
Post by MikaëlV »
Sure you want to make a slicer? There are so many of them available already - with many advanced options. It sounds like much fun though.
I hope and pray for Gcode enhancements for my Rostock 301 too. Any chance that this can be done too?
The supreme goal of course is to have a slicer that includes all the nice special features of the Geeetech printers.
Like color mixing for the Rostock, pause functionality (to insert objects in hollow places in your print, have flow control, acceleration and jerk control from your slicer.
Hope and pray - make me happy some day!
Let me know if you're looking for developers to update code - I'm game!
RecordBrownie
Post by RecordBrownie »
Oh! Wow, this link has so many 3d print software... thanks
RonS1955
Post by RonS1955 »
I seem to be having the same problems with Easy Print. I cannot save the changes I make to the printer configuration. it defaults to the D200 every time regardless of what I set mine at. I am using the i3 pro B and cannot save it, let alone hook up to my printer. Whats up with this software?
nobbyyyy
Post by nobbyyyy »
Tee software dont know that the I3 pro C has 2 extruders,
And i cant chose between
