Can someone help me, please. I want to do upload the firmware to control Board GTM32 proVb for a I3 M201, but when I followed the instructions on this Instruction with Hyperterminal and in point 6 this Instruction when I send firmware, opens another window, but in it nothing happens and after a while the new window appears with error message: "No response from remote system".
I have one other problem, the motor for Axis Z don't move, i think it's because the tension is not good, can you tell me what i can do?
thank you
firmware GTM32 ProVb inavailable?
Re: firmware GTM32 ProVb inavailable?
Check this post:
viewtopic.php?f=17&t=19104
franktattoos
#bang, can you see for the firmware Update please?
Since the start i can't update the firmware with HYPER TERMINAL. Always i have a error message, it's : No response from remote system.
It's NOT the USB cable, and the board card work because i making one or two print and can control the print with Simplify 3D
Please, i need this Update, i'm in Old version at this time.
Thank you
Thank you
Maybe you should reinstall the software,please check this post:viewtopic.php?f=20&t=17597
Can please someone download from the original plate firmware (*.hex or *.bin) i need to try uncrash my plate ?? I have GTM32 Pro Vb, whan i upload firmaware, it is everything OK, withno errors, but doesent work :/
BTW: any of this firware of my Prusa I3 M201 doesent work :/
Thanx
Thanx
Hi,you can upload the firmware with easyprint which's stable.You can find in this link:http://www.geeetech.com/specialpage/software/.bavant wrote:Can please someone download from the original plate firmware (*.hex or *.bin) i need to try uncrash my plate ?? I have GTM32 Pro Vb, whan i upload firmaware, it is everything OK, withno errors, but doesent work :/
Thanx
