Latest Marlin-1.1.0-RC8 For GEEETECH Prusa I3 Dual Extruder
pekote
Post by pekote »
This is up to now, the latest version for Marlin Firmware for GEEETECH Prusa I3 Dual Extruder. Works great!!! :D
I edited it with Geeetech parameters for prusa I3 Dual Extruder.
Compile with latest arduino 1.8.2
Do not forget to setup your extruder distance in configuration.h file, like below ->
#define HOTEND_OFFSET_X {0.0, 32.25} // (in mm) for each extruder, offset of the hotend on the X axis (BIGGER means 2nd extr go to left)
#define HOTEND_OFFSET_Y {0.0, 0.00} // (in mm) for each extruder, offset of the hotend on the Y axis
With this setting you don't need to setup any offset in slicer. Extruder separation is given from firmware.
Also it is necessary to setup an offset distance in order to print in center of the bed->
#define MANUAL_X_HOME_POS -17.0
#define MANUAL_Y_HOME_POS 0
Marlin-1.1.0-RC8 For GEEETECH Prusa I3 Dual Extruder.zip
(1.45 MiB) Downloaded 1368 times
Re: Latest Marlin-1.1.0-RC8 For GEEETECH Prusa I3 Dual Extru
Hi,thank you for your selfless sharing :D
pekote
Post by pekote »
I found that from time to time, printer could trip due to temperature protection.
New firmware have a new protection that takes care temperature diferencies between set point and feedback.
I attached some corrections to avoid trip due to its feature.
Marlin-1.1.0-RC8 For GEEETECH Prusa I3 Dual Extruder rev2.zip
(1.45 MiB) Downloaded 1180 times
Marc71
Re: Latest Marlin-1.1.0-RC8 For GEEETECH Prusa I3 Dual Extruder
Post by Marc71 »
Is this configuration good for i3 pro c ?
It suits your I3 Pro3 with dual extruder.
RoBra81
Post by RoBra81 »
would it be possible to use auto leveling with 3d touch sensor with this firmware?
Ronny
BarBE
Post by BarBE »
[quote=RoBra81 post_id=80411 time=1505300627 user_id=60742]
[/quote]
Hi Ronny, Auto leveling with the 3D touch sensor works fine with my Pro C and the latest marlin version (currently 1.1.5). Was about as easy to set up as the old firmware Geeetech provided. I haven't encountered any issues with it so far.
:D
NightStorm1000
Post by NightStorm1000 »
Heya.
Can someone update this to the Latest Version?
I already tried to compare the Configuration.h from this with the Newest one but this ist just way beyond me.
