Latest Marlin bugfix-1.1.x branch for PI3 Pro B
Rv8
Re: Latest Marlin RCBugFix branch for PI3 Pro B
Post by Rv8 »
Hello NiklasO
I thank you, could you please give me the link for your new firmware ? Thanks a lot :)
NiklasO
Post by NiklasO »
It's in the 1st post :)
Rv8
Post by Rv8 »
Yes ! it's great thank you, I download it and I will test the firmware after work :)
Rv8
Post by Rv8 »
Hey ! all works great right now ! I set the offset with 3d touch sensor manual and it work, I have a Z-1.8 for the offset and the result is better than before I use this sensor.
I thank you a lot NiklasO for your help ! It's great :)
Do you think I need to do a a "Level Bed" in the lcd menu ? or it's not usefull ?
Thanks again !
NiklasO
Post by NiklasO »
Great! Glad to hear that it is working now.
No, the bed level or set home offset is not something useful for us.
Rv8
Post by Rv8 »
Hello
Thanks again for your help, the print, is better now !
Rv8
Post by Rv8 »
Hello NiklasO,
I just want to notice you something, when the offset of Z axis is set to 1.9, there is a bug. I send the print and the X axis go to the right and hit the right of the printer, and return to the center and begin to print but it print in the air... :shock: :shock: :?
Very strange !
So with z-1.8 the offset is ok for me but I think my repetier setting is not very good..because parts don't fixe to the the bad and sometimes part go away ..."the bed is too hot !? 50°C and 210 °C extruder for PLA printing" so Could you give me your setting please ? it will be great :)
Thanks again !
NiklasO
Post by NiklasO »
The offset should be set to negative numbers. 1.9 is very high. ;)
Sometimes the printer starts to print in the air because the stepper motors has timed out. The printer does not know the location and starts to print in the air. You can see that on your LCD, if the locations has question marks, the printer has lost the location and needs G28 to fint it again.
Set DEFAULT_STEPPER_DEACTIVE_TIME to 0 in Configuration_adv.h and it will never time out and keep the steppers energized.
Rv8
Post by Rv8 »
Yes Ok I will try that, but now I will set a lower offset because there is not enough pla on the bed.
I will try 1.7, and see if it's good or if I need to set a lower value etc...
NiklasO
Post by NiklasO »
Offset should be between -1.0 to -1.9. Negative values only.
I will post my slicer conf later. :)
