Newb i3 pro C dual extruder - beginners q's
robmason
Post by robmason »
So I have just finished my first build
Hardware Q1) The dual extruder set-up has no way of reaching the x-axis stopper? The extruder motors hit the vertical rods beforre the stopper can be reached? What have i done wrong?
x-axis 'home' test goes left to right and 'grinds at far-right. I have updated firmware and switched direction - I assume home should be left as i look at it?
Z-axis only right-hand motor moving.....
Apologies for beginners ignorance - just learning!
Newopint95
Re: Newb i3 pro C dual extruder - beginners q's
Post by Newopint95 »
Is your extruder bracket on correctly? It has a small tab that sticks out to hit the x axis end switch. It is possible to mount backwards or upsidedown.
Hi,The X-axis should move to the left side after setting home.You can check this post about the wrong motor direction:viewtopic.php?f=17&t=17037.
