Rostock 301 firmware at 1.0.03 delta radius issue
davegalesr
Post by davegalesr »
I upgraded my firmware on my Rostock 301 to 1.0.03 and I do not see any effect when I change the delta radius value - the distance between the hotend and the bed does not change.
Re: Rostock 301 firmware at 1.0.03 delta radius issue
davegalesr wrote:I upgraded my firmware on my Rostock 301 to 1.0.03 and I do not see any effect when I change the delta radius value - the distance between the hotend and the bed does not change.
Hi,How do you upgrade the firmware?Maybe you can use EasyPrint to do that:http://www.geeetech.com/specialpage/software/.Besides,taking a video will be more clear to solved it.
davegalesr
I used Easy Print to update the firmware and that's when the delta radius stopped working. how can I revert back to 1.0.02?
Hi,you can do that by following this post.http://www.geeetech.com/forum/viewtopic ... 20&t=18167
