Hi,could you take a video about your issue?lucapon wrote:Hi, I tried inverting black and white pins but it doesn't work.. How can I do?
3d touch sensor g-code and endstop issues
Re: 3d touch sensor g-code and endstop issues
Sure, here's the link to a dropbox folder with videos: https://www.dropbox.com/sh/peqc4hbt923m ... 1u18a?dl=0
The first video is for wireing and power on and the second is for auto calibration
Hi,have you tried the following g.code that can be used manually to diagnose
faults?If the 3dtouch act what it should be,the 3dtouch is normal.please adjust the screw on top of the sensor.
M280 P0 S10 ; pushes the pin down
M280 P0 S90 ; pulls the pin up
M280 P0 S120 ; Self test – keeps going until you do pin up/down or release alarm
M280 P0 S160 ; Release alarm
I have tried that commands yet but nothing happened.
What can I do? Is a sensor fault?
Just installed mine and it is doing the exact same thing.
Pin goes up and down when you switch printer on but nothing else works
m280 p0 s10 and m280 p0 s90 does nothing.
Can anyone help ?
Can anyone help ?
Hi,I think you still need to adjust the sensor to the critical point at first.Follow this video:
https://www.youtube.com/watch?v=Ix7lXvf ... e=youtu.be.
You wrote it yet but I'm not in allarm mode and my sensor is yet to the critical point
I have the same problem with my 3d touch!
Tried every thing but the thing does not respond to the M280 command.
Tried the screw and changing cables.
When turning on the probe is going out-in-out-in and the light is red.
When sending M119 the end stops are all open
After inverting the Endstop in the firmware the Z-min is triggered.
When manual deploy the probe it is still triggered.
Now reading here there are a lots of people here with the same problem.
Also the M280 commands are NOT working..
When i want to home the Z the LCD is displaying Z Probe out. bed
Tought I bought a easy to install product. But it is already taking me 2 days with NO LUCK.
When returning to the default firmware without 3d-touch it works fine. but I hate leveling my bed every time I use the printer...
Hopefully anyone has found a solution
Are there other pins to test?
Code: Select all
> 14:27:36: N17 M280 P0 S10 *13
> 14:27:41: N22 M280 P0 S120 *57
> 14:27:48: N30 M119 *57
< 14:27:48: Reporting endstop status
< 14:27:48: x_min: open
< 14:27:48: y_min: open
< 14:27:48: z_min: TRIGGERED
> 14:29:01: N99 G28 X0.00 Y0.00 Z0.00 *102
< 14:29:03: echo:Z probe out. bed
fixed it.... Just solder the signal (orange cable) to the R22
And now it works like a charm!
Now calibrating time!!!
- R22
- Foto 07-05-17 16 24 36.jpg (235.07 KiB) Viewed 28126 times
