Z Axis home position [solved]
russellz
Post by russellz »
Just got my Acrylic Prusa I3 pro B working and tried my first test print.
I homed all axes and leveled the bed then loaded my stl file, sliced with Slic3r and hit print.
The printer tried to print the first layer about 2 mm above the bed - disaster. Searching the forum I found a number of posts regarding strange homing behaviour on the X axis. So I started to plough through the firmware source. In the file "Configuration_adv.h" I found this section:
Code: Select all
//homing hits the endstop, then retracts by this distance, before it tries to slowly bump again:
#define X_HOME_RETRACT_MM 5
#define Y_HOME_RETRACT_MM 5
#define Z_HOME_RETRACT_MM 2
The idea of this is that, if homing is done at high speed, the axis might overstep the switch actuation position with inertia so it retracts and tries a second time more slowly. The software assumes that the retraction is enough to de-activate the end-stop switch. If the switch is not de-activated by the retraction the software assumes that it has reached the activation point and stops any advance.
Changing the last line to
Code: Select all
#define Z_HOME_RETRACT_MM 5
and reloading the firmware fixes the problem.
It must be about time that Geeetech updated the firmware on the website and installed in supplied kits to fix all known problems - please.
Russell.
Re: Z Axis home position [solved]
Thanks for your sharing.
ZCC
Post by ZCC »
I have the same problem. I just upload the firmware with value 5 on Z retract and it still happens. I tryed reupload with "2" on Z retraction and the problem persist on the same way
My printer is a Aluminium I3 A Sanguino
Can you attach a video about your problem?
ZCC
Post by ZCC »
http://www.youtube.com/watch?v=29qzheZEon8
I tryed other slicer and the same problem. I will test update a new firmware changing the printer name, just to test if the arduino is really updating correctly
Thanks for your video showing the issue,you need to update your firmware version,and here is the link:
http://www.geeetech.com/forum/download/file.php?id=2819
ZCC
Post by ZCC »
William wrote: Fri Jun 30, 2017 2:35 pm Thanks for your video showing the issue,you need to update your firmware version,and here is the link:
Thanks for support.
This firmware don't fit in my sanguinolu board (At least, i cound't upload it).
I tryed upload the version "Plusa_I3_A_sanguinololu(for the upgraded kit using lead screw).zip" and it worked. Problem solved.
you are welcome,your problem solved that was the best.
