I've raised a ticket just in case, but I was wondering if anyone had any experience or suggestions.
When assembling the mainboard section, the positioning of the board fan doesn't match that in the build doc and videos I've seen - in those the board fan's off to the side of the mainboard, instead of parallel between the board and the LCD.
From that position, the fan lead's not long enough to plug into the socket, and I'm not sure about rotating the board 180degrees in case of difficulty plugging the USB connection in.
Have I missed anything obvious there?
Many thanks.
Rostock Mini G2S Pro board fan position changed?
sonicthehedgehog
Re: Rostock Mini G2S Pro board fan position changed?
I guess the holes for your fan were incorrectly drilled...
mclightning
Mine also same problem. Any solution for this? Is it dangerous to use the 3d printer in this arrangement?
It is obvious that the direction of installing fan is wrong that result to the difficult in plugging into the socket and heat dissipation .
the right position where there are several holes for installing fan has been marked in the picture.
- 20170807104324.jpg (26.45 KiB) Viewed 7301 times
