Hello, I recently bought a geeetech i3 w. Everything works correctly until I have tried to print from a sd card.
when the insert does not recognize it and from the software it says INIT FAIL.
What do I have to do to make her recognize her well? a greeting.
I am Spanish and I use the google translator.
SD INIT FAIL
Re: SD INIT FAIL
You should confirm your SD card is FAT32, Class 4. Then take it out and wipe it several times with a tissue and then try to insert it again.
