3d Touch @ Delta Rostock GS2?
DerSchlangen
Hi!
It is posible to improve my delta Rostock GS2 with a 3D Touch probe?
Can you tell me the wiring? I did not have a 3 Pin Port on my board like in your wiki instruction.
And could it be that the used port is blocked by the endstop of the axis?
greetings...
greetings...
Re: 3d Touch @ Delta Rostock GS2?
Yes, you can add it
You can refer to others who add 3d touch at the forum
DerSchlangen
Can you please give some links?
Here are tips for GT2560A+ wiring
(You should ensure your mainboard is GT2560 or GT2560A+)
DerSchlangen
Hello and Thank u!
It is not the Rev A+ wich is build in at my Printer.
Can you please descripe the wiring for GT2560?
You can refer to it
DerSchlangen
Hi!
There is a Problem in your instruction!
At the Delta Rostock G2S the Z-max connector is used for the z-max endstop. In your Instruction (maybe it is a prusa Printer?) they use z-max for 3D-touch.
Maybe i'am wrong but i can not use this pin otherwise there is a Problem in homeing the axis without z-max.
Do you have a instruction for Delta-Rostock Printer?
DerSchlangen
No one a idea or a hint? Some instruction?
I did not understand Marlin in that kind of way to change on y-min contact.
Please help. Could Geeetech give some hint?
