Goodmorning,
My object realised is all creased after 3 layer, however it was well glue with double face tape,
how can I correctly set the temperature of the bed please ? because it peels off all the time after 3 layer
Correct température for bed
Re: Correct température for bed
Have you tried to check the Z axis?
I think maybe the issue lead by the Z wobbling?
I have bed level sensor instaled, it's not the z axis the problem but i found some response to my problem,
I up the temp of extrudor and bed but i dont know the Good temp for bed with abs , cause the glass and tape double face retain some heat.
95 degree is good for abs ?
Thank
Thank
I check tath
Ty
Ty
100C for the first layer and others set to 90-100C will be better
