hi i have just fitted the 3d touch to my i3 pro b with gt2560 board, i found the firmware on this site but when i try and compile it i get this error
'error'
using typedef-name 'fpos_t' after 'struct'
here is the full error report
Arduino: 1.8.5 (Windows 10), Board: "Arduino/Genuino Mega or Mega 2560, ATmega2560 (Mega 2560)"
from sketch\BlinkM.cpp:5:
#define X_MAX_PIN -1
#define X_MAX_PIN 24
#define Y_MAX_PIN -1
#define Y_MAX_PIN 28
from sketch\ConfigurationStore.cpp:1:
from sketch\MarlinSerial.cpp:23:
from sketch\cardreader.h:8,
struct fpos_t {
sketch\Marlin_main.cpp: In function 'void set_bed_level_equation_lsq(double*)':
sketch\Marlin_main.cpp:998:36: warning: deprecated conversion from string constant to 'char*' [-Wwrite-strings]
planeNormal.debug("planeNormal");
exit status 1
option enabled in File -> Preferences.
3d touch i3 pro b firmware compiling error
Re: 3d touch i3 pro b firmware compiling error
You should upload the firmware via Arduino 1.0.1
I tried uploading to 1.0 and I still have an error as well.
"fpos_t" error seems because the latest Arduino version have more strict definition of the firmware
