I have a problem with a clogged nozzle
The filament broke and I tried to get it out of the nozzle. I heated it to 200-220 °C, then tried to push it out or through. Neither of it worked.
I attached images of the extruder and the nozzle.
Here you can see the filament sticking out: https://drive.google.com/file/d/1vF9Q0C ... sp=sharing
Here the nozzle: https://drive.google.com/file/d/1ydQdKl ... sp=sharing
I can't push the filament through, what else can I do to print again?
Clogged nozzle can't be fixed
Re: Clogged nozzle can't be fixed
You can use a wrench to remove the throat and remove the filament
Dustin0987
I remove the nozzle than hold it with pliers and hit it with a blow torch.
