Geeetech Prusa i3 Pro C - Impressions and Videos
BR365
Post by BR365 »
i will summarize here my impressions and experience with our Geeetech Prusa i3 Pro C 3D Printer.
Find here my Playlist on YouTube, showing my own print results and progress: https://www.youtube.com/watch?v=2UewBv3 ... -B0rU-WOW-
I appreciate Your comments, critics and, of course, subscription to my Video Channel.
Thanks,
Moritz
BR365
Re: Geeetech Prusa i3 Pro C - Impressions and Videos
Post by BR365 »
In this video, You see the 3D printing of a speaker box for railway modelling loadspeakers. Those small speaker boxes enhance the sound volume and bass.
https://www.youtube.com/watch?v=e9rw_Sm4C-4
BR365
Post by BR365 »
BR365
Post by BR365 »
I printed a PSU cover to enhance the electrical security of the power supply: https://modellbauhuette.dettenbachtal.d ... d-drucker/
This was the first print, looks quite good.
The second print was not so good, had to change the nozzle first and printed with higher temperature, 205°C:
Third print, even better, now again like the first print with 195°C.
I strongly recommend to apply this case to Your i3 Pro B/W/X models, because the electric installation is a real risk!
Find me on Thingiverse: https://www.thingiverse.com/Modellbauhuette/about
BR365
Post by BR365 »
Time Lapsed video from print process on my Geeetech i3 Pro C printer:
https://www.youtube.com/watch?v=BOsBLv3qI2Q
Post by _kaktus_ »
Hi.
:D
There is a problem with your link. Can you correct it :?:
I like your PSU enclosure. I made a bit different.
I wanted the power cord plug to be placed deeper and not to be an obstacle. ;)
BR365
Post by BR365 »
Hi Cactus,
thanks for the hint to the wrong link. It should work now.
With Your solution, the Power Plug is still open to the interior side of the printer. Or did You create two cases?
Moritz
Post by _kaktus_ »
Yes, you are right. :D
I am planning to make a second cover from the inside.
This will be the larger cover will also cover the threaded rods.
BR365
Post by BR365 »
Here is now my final Version 5 of the 250W PSU Cover:
https://www.thingiverse.com/thing:3429339
Post by _kaktus_ »
Hi.
Good work.
Now the cable is not an obstacle.
Is it easy to install this cover :?:
