Geeetech A30 and Cura
sasoromih.a@gmail.com
my printer connect easily to Simplify3D and EasyPrint but Cura doesn't recognize it. Any suggestions?
Re: Geeetech A30 and Cura
Did Cura show any information?
I find a video about Cura setting for A30, hope it can help you.
https://www.youtube.com/watch?v=TmsUA2rlV2k
This video is only how to setup profile in Cura. That is not the problem. My problem is that Cura doesn't recognize my printer on any of my two computers.
Can you place a Screenshot with the configuration you have entered?
Maybe you can try the old version of cura.sasoromih.a@gmail.com wrote: Mon Jun 04, 2018 11:55 pm This video is only how to setup profile in Cura. That is not the problem. My problem is that Cura doesn't recognize my printer on any of my two computers.
Welcome to Geeetech world:
https://www.facebook.com/groups/315127105604393/
Thanks. I already did and works.
GiuseppeScollo
May I ask you which older version of Cura solved the problem? I got Cura 3.4.1 installed and within a couple of weeks I should receive a Geetech A30 I just ordered. If possible, I should like to know in advance how to solve this problem, if it will occur.
If you also encounter similar problem, try version 15.04.6, baud rate set to 115200.GiuseppeScollo wrote: Fri Aug 17, 2018 7:42 amMay I ask you which older version of Cura solved the problem? I got Cura 3.4.1 installed and within a couple of weeks I should receive a Geetech A30 I just ordered. If possible, I should like to know in advance how to solve this problem, if it will occur.
