Y Axis Steeper Motor Very Warm
Hi guys
I have just fired up my A30 for the first time and doing a test print I have noticed that the Y Axis stepper Motor is very warm
Is this normal due to the weight of the larger bed it has to move?
Re: Y Axis Steeper Motor Very Warm
Is the voltage of the blue A4988 normal(0.6-0.9V)?
If so, then this might be a flaw that Geeetech is dealing with, you can participate in this vote in the Facebook group, we are collecting information:
https://www.facebook.com/groups/3151271 ... 791390123/
Hi Gingko
I have just checked the Vref and it was set at 0.955v so I have taken it back below the 0.9v and I will see if that makes any difference
By the way, I would like to draw your attention to the fact that the A4988 stepstick module can operate in two modes.
Its configuration is hardware-set. Depending on the mode selected, the current setting must be reduced.
Incorrect current settings result in a significant heating up of the controlled stepper motor.
For those who are curious and thirsty for knowledge, please refer to the datasheet.
My y axis was very hot causing the extruder to be moved mid print randomly to outside the xy axis (causing some awful noise from the motors).steveski21 wrote: Sat Jun 16, 2018 12:25 pm Hi guys
My voltage was 1.5v so on advice I've turned the x and z motors to 0.9v and the y down to 0.6v. The y is still warmer than the x but it is nowhere near as hot and I've not had any failed prints.
Hello guys, i notice i have the same problem,
but i have no idea how/where to check and set the voltage? does that require any special eletronics skills, or it's just parameteres in software?
You should minimum know how to work with a multimeter.
Very warm is also no big deal, under 80c you can complete ignore it, around 100c it get dangerous to damage the stepper.
This is a known issue with the A30. I've built 4 of them and each one had the stepper driver current set incorrectly. The Y-axis is the worst and will get hot enough to damage the motor. The extruder is also set very poorly and gets too hot.
I would recommend setting the Y-stepper driver to 0.6 to 0.7 volt and the extruder to around 0.5 volt.
On a side note while you're in there adjusting voltages, since there is only one Z-axis driver, and two motors, you want the Z-axis stepper driver voltage to be as high as you can get it - usually around 1.1v. Otherwise you will loose torque and miss steps.
Thank you all for generous help, anyway in my ignorance, i didn't understand your instructions.
I found this video which show that actually procedure is not that dificult, just words are dificult.
https://www.youtube.com/watch?v=p_TpiZSebxw
To be honest, before buying the printer, i thought it would be, just like click, PRINT, all the settings, preparations (software and hardware) are surprising me.
Btw. i am starting to love the 3D printing comunity, a lot of super genious people willing to share designs, knowladge etc...
Thanks.
Thanks.
