Print quality on i3 pro W
Derekchong
Can someone help on the print quality? The print on external wall layer have lots of gaps. Im using a 0.3mm nozzle. Does changing the nozzle to 0.4mm help? How to improve the print?
I have attache a photogrpahs of the print.
- Any advice?
- 20180806_220632.jpg (239.55 KiB) Viewed 14108 times
Re: Print quality on i3 pro W
But a beautiful printout. I would like to be able to do something like this.
I understand that you are not satisfied with the result achieved because you expected something completely different.
This may be due to insufficient filament flow.
To diagnose a problem, I have a few questions:
- 1. Have you performed any extruder calibration?
- 2. Can I hear an extruder click during the printing process?
- 3. Have you calibrated the mechanism in the X, Y, Z axes?
Derekchong
I have calibrated the extruder. No clicking sound during the print. Do i need to calibrate the x and y axis? Seems fine to me.
What kind of filament you use. What temperature have you set on the head?
Maybe it is worth to increase the temperature by 5℃ and test it?
Calibration of the axis is not mandatory, but it is worth to go through this process.
Derekchong
Im using ABS filament. 1.75mm. I have tried raised the temperature but seems it make no different. The temperature im using was 235. Increase it to 240 make no different.
Derekchong
I calibrated the z axes and the quality it improved a lot more!!! Thanks for the advice.
But now im hearing clicking sound from the extruder on some part of the print. I suspect the layer and nozzle could be too near. Any suggestion?
See my print.
See my print.
- 20180809_004555.jpg (157.2 KiB) Viewed 14047 times
I also use the ABS filament.
But I set the head temperature at 250℃.
What is your filament brand?
Derekchong wrote: Thu Aug 09, 2018 2:31 am I calibrated the z axes and the quality it improved a lot more!!! Thanks for the advice.
The printout shows that one page is more pressed against the work table.Derekchong wrote: Thu Aug 09, 2018 2:31 am But now im hearing clicking sound from the extruder on some part of the print. I suspect the layer and nozzle could be too near. Any suggestion?
See my print.
This may indicate that the work table is not level enough.
I expect that when the printer was doing that part of the printing, one could hear a click in the extruder.
You may want to try applying washer to the spring into extruder to increase its pressure.
Derekchong
I will try to put a shim in the spring as suggested. What do u mean my work table is not level? Is my print bed not level that lead to the clicking sound?
work table = heat bed
I mean that the levelling procedure has to be done very precisely. As good as you can.
