Nozzle drops after ~ 1 min
clausdk
Post by clausdk »
We have a small problem with our newly built Delta G2S printer. The noddle drops, like the step motor turns off.
Heres a video of what happens:
https://www.youtube.com/watch?v=9rkdc-Pt3tw
In this video we just started the printer, no usb connected. Centered the noddle with the "Auto Home" command. Then we wait 1 min and it drops to the bed.
It also does that when using the EasyPrint3d program.
Maybe someone knows what could be causing this?
Best regards,
Claus
dohabandit
Re: Nozzle drops after ~ 1 min
Post by dohabandit »
Go to thingiverse, there is a carriage clip you can download that you place on the vertical bars and when the printing is done it will prevent the spider from dropping. The issue is that after a while the controller turns off the stepper motors which are then free to spin and the weight of the spider causes it to drop.
