Bed Temperature Offset
So i'm fairly sure the bed temperature scale is off by some factor. When the bed heats, it heats to whatever "number" you set it to. But when the bed cools to room temperature, it cools to 0 degrees C... and its definitely not that cold in my house.
I haven't measured what the offsets are, but it seems that this is something that should be corrected in the next firmware. The hotend reads close enough, but also appears to be off somewhat on the cold/base temperature.
Re: Bed Temperature Offset
Hi.
The manufacturer has adopted a scenario where it is known that the heating is switched off.
