A10 auto level sensor
Gingko
Re: A10 auto level sensor
Post by Gingko »
Sorry, the red line seems to connect to VCC, let me confirm tomorrow! :oops:
Gingko
Post by Gingko »
brown--GND
red--VCC
need to do a little modification for the connector of 3 pins.
Wolle82
Post by Wolle82 »
Please... can U show us a complete working setup? No mistakes, please. I am confused now.
This image is from http://www.geeetech.com/wiki/index.php/ ... ing_Sensor:
This is the board:
So... can U please show EXACTLY how to connect? Don't change colours.
gdachs
Post by gdachs »
You have to exchange red and orange.
Wolle82
Post by Wolle82 »
So it looks like:
Code: Select all
Endstop connector:
VCC [red]       |   VCC
Z_MAX [orange]  |   Z_MIN [white]
GND [brown]     |   GND [black]
VCC             |   VCC
Y_MAX           |   Y_MIN
GND             |   GND
VCC             |   VCC
X_MAX           |   X_MIN
GND             |   GND
Wolle82
Post by Wolle82 »
Here is a picture of correct wireing:
Have fun!
Wolle82
Post by Wolle82 »
Well now, when there is someone out there who can give us a cool or simple STL file for a 3DTouch mount for the Geeetech A10 it would be very nice! Maybe you have designed one yourself... Please share.
Wolle82
Post by Wolle82 »
RepMike
Post by RepMike »
Question - can anyone point me to a tutorial on how to setup a Capacitive Proximity Sensor with the Geetech A10? Can I use the connectors on the Extruder? If so, how are they being wired?
Thank you in advance
Wolle82
Post by Wolle82 »
The A10 has no extra connectors to connect the sensor at the hotend/extruder... you connect it to the Z endstop on the mainboard directly as I know.
Further there a 3 methods to connect it to the Z endstop:
1. directly connect the sensor (not recommended - voltage to low with 5V for the sensor. The sensor is about 6-36V.)
2. use an octocoupler (safest but more tricky - use 24V with the sensor, separated 5V from the mainboard for the signal)
3. use a voltage devider (easy and cheap - use 24V with the sensor and devide the voltage to 5V for the signal)
Hint:
When U want to use the voltage devider (3.) you should know that the sensor (LJC18A3-H-Z/BX) itself has a build-in resistor at 10kOhm. Use a 2.2kOhm resistor to devide the voltage from 24V to 4.5V. When U got an other sensor find out its resistor value first (if present). That should be the easiest way... And don't forget to solder the resistor first before you connect to the board!
Here is my mount: https://www.thingiverse.com/thing:3146974
