Ooops!!!
keyser187
Ooops!!!
Post by keyser187 »
Tried to drill out the hole to 8mm as it was under and had to hammer the threaded rods in.
:o :shock: :?
It didn't work!, I won't be printing for a while
but thank %#&% RDR2 is out in a few weeks.
Gingko
Re: Ooops!!!
Post by Gingko »
The 8mm hole didn't fit the threaded rods so that you have to drill it?
keyser187
Re: Ooops!!!
Post by keyser187 »
the 8mm hole in the coupler was under size ( 7.8-7.9) so the threaded rod was a very tight fit which i had to force in.
so i tried to drill it to 8mm :? went in ok but snapped coming out.
recently upgraded to lead screws and new black couplers 8-)
but now i managed to snap a pin on the y axis end stop :evil:. Does anyone know which end stop i need to buy to fit the GT2560 as it only has 2 pins and the ones im finding on amazon and geeetech site are 3 pins and dont look like they will fit where my old ones are placed?
Re: Ooops!!!
Post by _kaktus_ »
Hello.
For a new topic you should create a new post.
With limit switches it is so:
  • 3 pins
    You can select the type of action,
    1 - disconnects 2 outputs after switching,
    2 - after switching connects 2 outputs.
  • 2 pins
    You have no choice of functionality,
    It works only in one way, its type you have to choose when you buy it.
:D
keyser187
Re: Ooops!!!
Post by keyser187 »
Apologies, ill make a new post.
