Which slicers work best with A30?
My A30 is still pausing during large prints, screen displays print paused, and the hotend returns to home position, nozzle heat and bed switch off. I can press the resume button, but if the bed cools first then the print releases and fails. I cant complete any larger prints because of this issue.
New 24V model of A30,upgraded firmware to the latest, did not fix the problem. Still pauses at random. I did the firmware updates without taking the box apart to remove the hidden SD card, is that something that has to be done? The firmware seems to have flashed ok.
I am using Cura 3.5.1 . Do you think there is something wrong with the printer itself or am I getting Gcode errors? Should I try an older Cura version?
I have no Idea what to try next.
Re: Which slicers work best with A30?
Personal Recommendation.
- Update the Firmware
- Slic3r P.E.
https://github.com/Geeetech3D
so far i heard Cura 1.5.1 make just trouble
- Slic3r P.E.
I downloaded Slic3r PE and will try some of these files again. If it works, I wont be using Cura any more.
Also, what G-code flavor is used with this printer? Marlin?
Simplify 3D works great as well, although it is an expensive software.
Since the A30 is a Creality CR-10 clone, most of the slicer settings work good for it. You can start with a base CR-10 profile and modify it to fit the A30.
I have a pretty solid profile I'll share if anyone with Simplify3D is interested.
I started slicing using slic3r PE. The print quality is a little better, and it was easier to dial in the printer than Cura. I still get a random pause during prints, not as often as before, however.
Hello,dekes1 wrote: Mon Oct 29, 2018 1:41 pm I have a pretty solid profile I'll share if anyone with Simplify3D is interested.
I also use S3D with the A30. I would like to test your profile.
Here's two A30 profiles you can experiment with:
Best?
Maybe you can try to use the slic3r then set the layer to 0.1mm
I fixed my pausing issue. One particular SD card I was using would cause the printer to pause at random, it wasnt a firmware or a slicer issue.
I did purchase S3D, and I am glad that I did. There is a pre-set profile for the A30 in S3D that actually works, the thin-walled printing and support structures in S3D are fantastic. The interface isnt as pretty as Cura, but the printing results are amazing. I was reluctant to drop $150 on software but I am glad that I did.
