Error when starting the Repetier Host.
can anyone explain this error code i am really new to this
- Untitled.png (11.75 KiB) Viewed 15477 times
Re: Error when starting the Repetier Host.
Hello.
Do you follow the Repetier-Host installation instructions
https://www.repetier.com/documentation/repetier-host/
Everything is described in detail, it is difficult to do something wrong.
Read the Installation and Configuration document.
If there are any doubts later, we will dispel them.
i did but i have thought of installing and trying all over
In this case, you must install the missing Slicer engines.
hi thanks for the replies ...I uninstalled repetier and installed the latest one today now printer seems to be working fine
