TMC2208
TMC2208
Hi guys,
I have a problem with my A30 and maybe you will have the answer...
I just changed the drivers to TMC2208 and this sh!*t is briliant !!! but, somehow I can't make it work on the X...
Y,Z and E working great, but the X don't want to lock or move.
When I home the X, it's working, but refuse to move from there.
I tried Vref, and changing to another TMC2208 but nothing.
Back to the A4988 and the X is live again.
Any ideas????
BTW, the board is Gtm32 pro vd
Any ideas????
Re: TMC2208
GTM32 Pro ? Normally the A30 have the mini, anyway look here
https://www.geeetech.com/forum/viewtopi ... 92&t=61761
Re: TMC2208
Yes, I got it with the Pro.
I already removed the bridge and update firmware, but it's the same problem
Re: TMC2208
Hey
Could you tell us your fw version?
You need to tell us your PSU type also(12V or 24V).
Re: TMC2208
Hardware version 3.2 24v
Latest firmware.
Latest firmware.
Re: TMC2208
The latest firmware version is:V1.37.58.You need to update it to this firmware version then test it.
Re: TMC2208
I have the same problem. HW version 2.1, 24V PSU.
When I upgrade to FW 57 or 58, X works until I execute G28, or G28 X. After homing - X axis is dead.
On 56 it seems to be working (with TMC2208 drivers) but I am worried as the linked thread says I need to have newer firmware.
I measured voltage on X axis driver while homing - there are no drops or changes, it is same after homing but stepper won't move anymore.
Re: TMC2208
Actually after some printing, issue happens in V56 too. For now I will just remove G28 and manually make sure that axes are homed before every print. I will upgrade again to 58. If you need me to test anything (test builds), you can contact me (I am also in group on FB, you can message me).
Re: TMC2208
Thanks for your feedback,we will check it'goranobradovic wrote: Sat Nov 17, 2018 4:35 am I have the same problem. HW version 2.1, 24V PSU.
Re: TMC2208
Hardware Version 3.2 have the GT32 Por Bord and need a modified Firmware version for TMC's
