Geeetech A10 with GT2560 V3 suddenly died
gdachs
Re: Geeetech A10 with GT2560 V3 suddenly died
Post by gdachs »
_kaktus_ wrote: Fri Nov 02, 2018 4:30 pm It is a pity that you did not come up with it to show the PCB from below. :roll:
In the diagnosis a visual check is a very important step.
But you know it and you certainly looked carefully at whether the PCB does not have any damage, or a foreign element. ;)
Yes, there was nothing.
_kaktus_ wrote: Fri Nov 02, 2018 4:30 pm I have seen the connected USB cable. Is a short-circuit also present when it is not connected :?:
In the third video there is no USB cable connected.
_kaktus_ wrote: Fri Nov 02, 2018 4:30 pm Let us know quickly.
My main goal is not to make the diagnosis, but to get a new board. So I did what I thought the Geeetech support might expect me to do.
But now I am heavily frustrated because of their lack of knowledge.
So my plan is now to wait for the next email from the Geeetech support and continue with building my Hypercube Evolution.
_kaktus_ wrote: Fri Nov 02, 2018 4:30 pm ps
I always carry out diagnostics with the electronics completely dismantled (if possible). This will solve a few problems that may occur. :roll:
I try to prevent this if I still have warranty.
Post by _kaktus_ »
That's how I looked at the movie again, and yes, the USB cable is connected to the device underneath.
I also looked at the diagram of GT2560 v3 and there are no more power keys there.
So so far I have acted a bit hastily. :?
I'm afraid that without a diagnosis you may not get a new controller board quickly. :roll:
For me it is the solution of this case that is interesting. :D
gdachs
Post by gdachs »
_kaktus_ wrote: Fri Nov 02, 2018 5:05 pm I'm afraid that without a diagnosis you may not get a new controller board quickly. :roll:
There is nothing left I could do without using a soldering iron. Next step would be to lift up the pin 3 of the MP2303A from the PCB, to check whether this chip is the culprit, or one of the diodes and capacitors, but I am old and my eyes are not good enough anymore for this kind of work.
I don't want to invest much more work into this task. If I don't get a free replacement, I will not buy a new board. In this case I will exchange the board with a MKS GEN L. It is just 6 mm wider, and much cheaper. This board works just fine in my Hypercube with Klipper firmware. I would need only to build some adapters for the Molex connectors, and I have an unused MKS TFT32 that is even much nicer than the display of the A10.
Post by _kaktus_ »
It's a pity that I won't know the solution to this curious defect. :roll:
The solution could contribute a lot.
But I understand you a little bit. ;)
On the other hand, it is good to know the reason for the defect. :idea:
ps
For me these small elements are not comfortable either.
Also do not blame young people from the support of Geeetech.
Everyone can make a mistake. Each of us has a different mentality, and there is also a language barrier.
The world is open to them. They are able to achieve a lot. ;)
gdachs
Post by gdachs »
Geeetech support agreed to send me a new board, but after I sent them the ordering information, all communications stopped. No reaction anymore on my emails. They sell the board now for $52, but before I go this way, I will better change to a MKS Gen L. It is much cheaper and I have better experiences with it, but okay, I told this already.
gdachs wrote: Wed Nov 14, 2018 4:20 am Geeetech support agreed to send me a new board, but after I sent them the ordering information, all communications stopped. No reaction anymore on my emails. They sell the board now for $52, but before I go this way, I will better change to a MKS Gen L. It is much cheaper and I have better experiences with it, but okay, I told this already.
I think you need to contact the sales.
Ask them to send you the new board.
As I know, tech support team can't send the replacement directly.
gdachs
Post by gdachs »
Tech support asked me for the order number, so I expect that they can forward that to the sales.
Kyle3465
Post by Kyle3465 »
Did you ever get a new board from Geetech?
