Hello, I recently finished the assembly of the prusa i3 pro W, but while doing the first print I faced the following problems:
https://www.dropbox.com/sh/0dwvcim5j1nc ... pcfaa?dl=0
The z axis is having trouble moving up and down, it gets stuck and makes a lot of noise. I tried taking out the threaded rod and noticed that one motor is moving first and then the other so it destabilizes. Also, the x axis is not moving much.
The problem with easy print is that when I start the job nothing happens, the extruder and the heat bed stays off, I don't know if it's a connection problem, I tried heating the extruder and the bed manually and it worked.
Z axis and easy print problem
Vanessagcal
Jump to
- Update Announcement/Product Release
- Firmware
- 3D Printer
- ↳ Thunder
- ↳ Mizar Pro
- ↳ Mizar S
- ↳ Mizar
- ↳ Geeetech I3/DIY Printer Series
- ↳ FAQ-Geeetech I3/DIY Printer series
- ↳ Geeetech I3 Pro B
- ↳ Geeetech I3 Pro W
- ↳ Geeetech I3 Pro X
- ↳ Geeetech I3 Aluminum
- ↳ Geeetech I3 Aluminum Pro
- ↳ Geeetech I3 Duplicator 5
- ↳ Geeetech I3 Pro C
- ↳ Geeetech I3 M201
- ↳ Geeetech A10 Series
- ↳ A10T
- ↳ Geeetech A20 Series
- ↳ Geeetech A20
- ↳ Geeetech A20M
- ↳ A20T
- ↳ Geeetech A30 Series
- ↳ A30M
- ↳ A30 PRO
- ↳ Geeetech E180 Mini
- ↳ Geeetech MeCreator2
- ↳ GiantArm D200
- ↳ Geeetech Delta Series
- ↳ Geeetech DP200 Series
- 3D Printing Software
- ↳ Configuration Profiles Sharing
- ↳ Software
- ↳ Wifi Box
- ↳ Bug report
- ↳ Download
- Hardware
- ↳ 3D Printer Hardware
- ↳ Stepper Motor
- ↳ Control Board
- ↳ Extruder
- ↳ Hot bed
- ↳ LCD Panel
- ↳ Power Supply Unit
- ↳ Assembly
- ↳ Others
- ↳ Video about cleaning and replacing nozzles
- Print Quality
- Resoures Sharing
- Feedback&Suggestion
- Project Talent Show
- Other Discussion
- ↳ Leveling Guide
- ↳ Open Hardware
- ↳ Mods And Hacks
- ↳ Products FAQ
- ↳ Tips & Tricks
- ↳ Discuss & Help
- ↳ Windows
- ↳ MAC
