Building an I3 Pro W. Pretty much built.
The heating wires for the extruder and the heatbed need connecting to the green or blue connection points on the bottom of the control board. I don't understand the connection. There is no bare wire visible. Do I need to strip the end of the wires before I put them in?
Stripping power wires for heating elements
Re: Stripping power wires for heating elements
Hello.
Can you show the photo
Attach your photos,please.
Photo of the ends of the wires that need connecting:
https://i.imgur.com/5YW26IM.jpg
HI
You thought well.
On your own, you have to remove the insulation from the end of the wires.
It is also good to solder the ends with tin.
You thought well.
Kaktus is correct._kaktus_ wrote: Wed Nov 28, 2018 11:06 pm HI
You thought well.
It is also good to solder the ends with tin.![]()
