//#define FILAMENT_WIDTH_SENSORvert wrote: Mon Dec 17, 2018 2:47 amwhat the entire 4 lines it takes to control the bltouch?zonalimitatore wrote: Mon Dec 17, 2018 2:45 am I've write my own firmware,and I haven't filament sensor enable.![]()
3DTouch / BLTouch auto leveling sensor GCODE for GT2560 Rev B
zonalimitatore
Re: 3DTouch / BLTouch auto leveling sensor GCODE for GT2560 Rev B
zonalimitatore
I too try several firmware,and for this i write my own.All functions i wanna work,but not the bltouch.vert wrote: Mon Dec 17, 2018 2:59 ami tried every firmware offer here and official before i was like there all garbage and made a decent firmware.
if you don't want to listen to people that know what there doing and have spent 100s of hours testing to confirm things work by all means struggle on your own.
I follow 2 guide.
1 https://cdn.thingiverse.com/assets/05/0 ... to_A10.pdf
2 http://www.geeetech.com/forum/viewtopic ... 76&p=88256
Not work in both
my width sensor and filament are disable
zonalimitatore
Ok.
For you what it's my problem?
I enable in config.h
Code: Select all
#define bltouch
#define Z_MIN_PROBE_REPEATABILITY_TEST
#define AUTO_BED_LEVELING_BILINEAR
#define Z_SAFE_HOMING-
zonalimitatore
So u dont wanna help me if i send the source?
zonalimitatore
Yeah me too.
I stay in v2
where i find yours?
my printer it's the first version with rev b board
I stay in v2
where i find yours?
Last edited by zonalimitatore on Mon Dec 17, 2018 3:43 am, edited 2 times in total.
zonalimitatore
Ah....and how i have to wire? using thinkiverse or thread here on forum?
zonalimitatore
yep...but in one of solution there is a change of pin zmin and max
zonalimitatore
infact zmin i've eliminate
I try your firm....but there is not my board. gt2560 rev B
zonalimitatore
true....same pin
When come back at home i write yours
zonalimitatore
I try to flash.Same things...doesn't work
