Check your v-wheels
AFewSkroosLoose
Check your v-wheels
Post by AFewSkroosLoose »
This is info to maybe help others.
I had problem with y-axis 'catching' in a few spots as it rolled back and forth. The catch seemed to be in time with the rolling diameter of a v-wheel. I did a test to find the bad one - use two at a time and mount in the smaller non-eccentric holes in bed mount plate. Push plate against groove in extrusion and slide back and forth keeping it steady and aligned with some pressure. I felt the catch and using this method found the bad bearing that must have had a flat spot. I used two good bearings in the solid mount holes, and the one good bearing left in the eccentric mount between the other two. Feels plenty stable when tightened properly and the 'catch' is gone.
If any axis exhibits the stuttering or catching, it could be a bad v-wheel.
Gandire48
Re: Check your v-wheels
Post by Gandire48 »
Thanks I have been having problems with my prints shifting to the "Y+" side. and have noticed the bed travel catching or running over something on the rails. will check my roller wheels :)).
AFewSkroosLoose wrote: Wed Sep 12, 2018 12:23 am This is info to maybe help others.
You are correct.
If the V-wheels broken the movement of Y axis will abnormal.
:D
Try to contact the sales to send you the replacement
Akuma
Post by Akuma »
I've had a similar problem since I got the A10M. It's not the bearings though, it's the wheels. They seem to be like memory foam and leaving them in one place for any length of time makes a flat spot where they sit. I have tested this by moving it off it's spot and feeling the bind where it has been sitting, then holding the wheel while moving it along, and repeating this with 3 other wheels to push the flat spots all out of sync with each other and mitigate the effects of the flat spots on the wheels. This works until it is left alone for a few hours and the soft plastic wheels develop new flat spots. The tension isn't that tight as I can hold the wheels while moving the Y axis, so I am at a loss as to what to do about this problem other than keep resetting the flat spots each time.
I'm surprised that more comments haven't been made on this poor design.
Gandire48
Post by Gandire48 »
One of my table wheels was not touching the guide rail. so I adjusted it some so now all 4 wheels roll. I Still have my prints Constantly shifting off in the "Y+" direction . Not the "Y-" direction. And the slightest extra drag will knock the print off postion. I have ordered the stronger SKU 700-001-0283,,,42SHD3418-24B20 to see if that will help.
Akuma
Post by Akuma »
Mine are all gripping okay, just seems like cheap rubber that's used for the wheels. I tried easing them off but same problem. Wherever the bed sits, the wheels get flat spots as if they have a flat tire, but the bulge stays where it is. I get no layer shifting at all if I run at a mild speed with travel at 120mm/s.
Sounds like you have different problems to me.
Gandire48 wrote: Sun Dec 16, 2018 3:38 am One of my table wheels was not touching the guide rail. so I adjusted it some so now all 4 wheels roll. I Still have my prints Constantly shifting off in the "Y+" direction . Not the "Y-" direction. And the slightest extra drag will knock the print off postion. I have ordered the stronger SKU 700-001-0283,,,42SHD3418-24B20 to see if that will help.
I think you can adjust the vref o the A4988 at first
Akuma wrote: Sun Dec 16, 2018 4:26 am Mine are all gripping okay, just seems like cheap rubber that's used for the wheels. I tried easing them off but same problem. Wherever the bed sits, the wheels get flat spots as if they have a flat tire, but the bulge stays where it is. I get no layer shifting at all if I run at a mild speed with travel at 120mm/s.
Have you tried to contact the sales?
Akuma wrote: Sat Dec 15, 2018 8:43 pm I've had a similar problem since I got the A10M. It's not the bearings though, it's the wheels. They seem to be like memory foam and leaving them in one place for any length of time makes a flat spot where they sit. I have tested this by moving it off it's spot and feeling the bind where it has been sitting, then holding the wheel while moving it along, and repeating this with 3 other wheels to push the flat spots all out of sync with each other and mitigate the effects of the flat spots on the wheels. This works until it is left alone for a few hours and the soft plastic wheels develop new flat spots. The tension isn't that tight as I can hold the wheels while moving the Y axis, so I am at a loss as to what to do about this problem other than keep resetting the flat spots each time.
Could you attach the photos?
Maybe you can feedback to the sales.They will send you the replacement.
Sneakers
Post by Sneakers »
I had the same problem with my A30. I think the wheels must be super cheap. I ended up replacing all the wheels on my X and Y carriage with these: BIQU V-Slot Wheels now everything slides smooth.
