Geeetech Superplate - NTC-MF52AT Thermistor
flat-jack
Post by flat-jack »
is it possible to get a datasheet for the NTC-MF52AT thermistor used in the following heatbed:
https://www.geeetech.com/geeetech-super ... -1019.html
It is nowhere mentioned which preset should be used in the Marlin configuration.h.
Maybe you could tell me wich preset to use? Or with the datasheet I am able to write my own temptable.
Thx
Re: Geeetech Superplate - NTC-MF52AT Thermistor
Post by _kaktus_ »
flat-jack
Post by flat-jack »
Hi, thx for the Datasheet.
But having a problem with finding the correct thermistor in it.
On the geeetech homepage, under specification it is writen: "Resistance value at R25℃ = 80KΩ"
But there is no such thermistor in the datasheet.
Maybe you can tell me the correkt B-value of the thermistor?
Thx for your help.
Post by _kaktus_ »
Hi.
Ask the GT sellers.
I don't know what they wrote, but you can do the experience and measure the resistances at a certain temperature.
