Endstops not registered!!!
Martin L.
Re: Endstops not registered!!!
Post by Martin L. »
Did you connect the end stops correctly? I have the problem if I put the wiring wrong that the end stops do not work. Check if the plugs are in the correct position and have all contacts. Check if the wiring fits the instructions
https://www.geeetech.com/Documents/Acry ... uction.pdf
