I've many Problems to using Simplify3d to print with only one filement, left or right side.
Are there somewhere some settings for Simplify3d ?
A10M Simplify3d Settings
buttervonwaffle
Re: A10M Simplify3d Settings
I personally use cura, And I have ended up using Makers Muse 3d printing profile I do believe it came from one of his viewers, because they where trying to fix some stringing issues. He took time to correct any issues that the ender 3 had, and the best part the Geeetech a10 is an ender 3 clone, so this profile is perfect for the Geetech a10! He also has a 3d printer profile for simplify3D heres the link to it. makers muse ender 3 profile You dont have to pay for the download, he just has it setup for if you want to throw him some cash for the download you can. But the profile should help save you some time on setup.
Heres the cura profile download link as well - cura profile
Plus his video here subscribe to the guy hes definitely knowledgeable - video here
I have used his profiles and he definitely has them down pat.
Edit: I just realized it said A10M. So you will need to do some changes for the dual extruders. But same basic concept at least.
If something I said just helped you out tremendously you can drop a little ramen money, the coding monkeys in my basement will appreciate it - Feed them here
You can private message me if you have any questions I might be able to help.
Thanks, i'll take a look at it,
but since i'm using S3d also for my Any i would prefere to use S3d for all of my printers
Did you sort this out, I am also using S3D and likewise the left/right extruder is very confusing. Plus also have you managed to get a good print. I am having problems with the extrusion multiplier setting
sorry for the late reply,
S3D send me a profile, that works
attached
attached
- Geeetech_A10M_PLA_RightExtruder.7z
- (3.09 KiB) Downloaded 1470 times
how do I set up S3D . After slicing, i'm only going to get this or nothing.
Thanks Ales
Thanks Ales
- S3D_2.jpg (279.92 KiB) Viewed 25326 times
- S3D.jpg (179.43 KiB) Viewed 25326 times
