Marlin-bugfix-2.0.x for Geetech I3 A Pro with Leadscrew and auto bed leveling and TMC2130 drivers by Hamed
here is the firmware for my I3 A Pro printer which works accurate and very quiet with TMC2130 stepper drivers on X and Y axes.
- Marlin-bugfix-2.0.x-Geetech I3 A Pro-LeadScrew-Auto Bed-TMC2130.rar
- (9.72 MiB) Downloaded 996 times
Re: Marlin-bugfix-2.0.x for Geetech I3 A Pro with Leadscrew and auto bed leveling and TMC2130 drivers
Thanks for your sharing!
Good job!
I do hope you can help please, as I have been trying to sort this out for the past 12 months.
Thank you for posting but is there any chance you could post one for the original A4988 and auto bed leveling enabled.
Mine has a 3D Touch.
https://www.thingiverse.com/thing:2039119
And I have set the settings for my fan / probe to :
Code: Select all
define X_PROBE_OFFSET_FROM_EXTRUDER -20 // X offset: -left +right [of the nozzle]
define Y_PROBE_OFFSET_FROM_EXTRUDER -44 // Y offset: -front +behind [the nozzle]
define Z_PROBE_OFFSET_FROM_EXTRUDER -1.0 // Z offset: -below +above [the nozzle]Re: Marlin-bugfix-2.0.x for Geetech I3 A Pro with Leadscrew and auto bed leveling and TMC2130 drivers
it's easy just comment outfrogsuk wrote: Thu Jan 17, 2019 11:02 pm I do hope you can help please, as I have been trying to sort this out for the past 12 months.
Code: Select all
define X_PROBE_OFFSET_FROM_EXTRUDER -20 // X offset: -left +right [of the nozzle] define Y_PROBE_OFFSET_FROM_EXTRUDER -44 // Y offset: -front +behind [the nozzle] define Z_PROBE_OFFSET_FROM_EXTRUDER -1.0 // Z offset: -below +above [the nozzle]
Code: Select all
//#define X_DRIVER_TYPE TMC2130
//#define Y_DRIVER_TYPE TMC2130
//#define Z_DRIVER_TYPE A4988
//#define X2_DRIVER_TYPE A4988
//#define Y2_DRIVER_TYPE A4988
//#define Z2_DRIVER_TYPE A4988
//#define Z3_DRIVER_TYPE A4988
//#define E0_DRIVER_TYPE A4988
//#define E1_DRIVER_TYPE A4988
//#define E2_DRIVER_TYPE A4988
//#define E3_DRIVER_TYPE A4988
//#define E4_DRIVER_TYPE A4988
//#define E5_DRIVER_TYPE A4988Code: Select all
#define X_MIN_PIN 22
#define X_MAX_PIN 24
#define Y_MIN_PIN 26
#define Y_MAX_PIN 28
#define Z_MIN_PIN 30
#define Z_MAX_PIN 32Code: Select all
// TMC2130 setup
//#define X_CS_PIN 24 //x max
//#define Y_CS_PIN 28 //y maxRe: Marlin-bugfix-2.0.x for Geetech I3 A Pro with Leadscrew and auto bed leveling and TMC2130 drivers by Hamed
just a quick question regarding the GT2560 and TMC 2130 drivers.
Did you modify the board wiring or does the GT2560 support ISP control of the drivers out of the box?
Best regards
Onki
Best regards
Onki
SoftandMoist
Hamed,
Your Pro A has the updated leadscrews, 3d touch and TMC2130, so.....
If I'm going to replace the stock steppers with TCM2088's, I'll change the following from
to
I'll also have to change the probe offset as well
So if the connections are correct on the control box.....this should all just work, yes????
Code: Select all
#define Z_DRIVER_TYPE A4988Code: Select all
#define X_DRIVER_TYPE TMC2088_standalone
#define Y_DRIVER_TYPE TMC2088_standalone
#define Z_DRIVER_TYPE TMC2088_standaloneI'll also have to change the probe offset as well
