Pro W Z axis problem
ChaseM
Post by ChaseM »
So every time I auto home, the z axis goes to a completely different position. When I try to home just the Z axis, it’s raises it by 2.2mm each time I press it. I’m fairly positive that the issue is firmware related but each time I try and update it or go to an older version I get different results. Any help on what I’ve done wrong?
Erdie
Re: Pro W Z axis problem
Post by Erdie »
hi there,
first download arduino 1.0.1
http://www.geeetech.com/forum/viewtopic ... 13&t=17181
than the firmware (number 13)
you have to open the firmware from arduino 1.0.1 and load it on the printer.
hope the links will help you.
Starbucks Coffee
Post by Starbucks Coffee »
Which version from #13 is best to use.
