Can't print a thing
diler35
Re: Can't print a thing
Post by diler35 »
I rised up the bed temperature to 70° and extruder to 230°, guess what? it makes no difference still same thing happens this printer is really waste of money!
diler35
Post by diler35 »
vert wrote: Sun Dec 30, 2018 5:52 am
diler35 wrote: Sun Dec 30, 2018 5:46 am I rised up the bed temperature to 70° and extruder to 230°, guess what? it makes no difference still same thing happens this printer is really waste of money!
I do 24h long prints on my a10 your blaming the hardware for lack of skill. The video proof is on my YouTube channel check it might learn something.
Im sure you're more talented than me, you are the best DIY guy on this planet but this printer is not working as it should be the day it get out of the box.
Well, somethign is wrong with this printer, i have fixed/repaired many things but this machine just don't want to be repaired.
Best Regards
andileibi@web.de wrote: Sat Dec 29, 2018 7:06 am Hello, I had the same troubles, try to print with higher nozzle temperature. My one is working well now but only with a nozzle temperature of 230°C for PLA
You need to use the PID tuning then check the ptfe tube plug to the hotend enough.
lenkiely
Post by lenkiely »
Dont know if I am too late with this post but, I had the same issues, I have now increased my extruder temp to 210 degree, my glass bed at 75 degree and I now use a very sticky hair spray,,,all is perfect for me now.
lenkiely
Post by lenkiely »
Oh!!!!!!
I also use the geeetech parts paper to set my height, It seems to be a different thickness than an A4 sheet, If you had a good quality gloss print paper, that also adjusts height good.
lenkiely wrote: Mon Jan 07, 2019 2:48 pm Oh!!!!!!
:D
Thanks for your suggestions.It will help others a lot.
3dralf
Post by 3dralf »
I have also many prob printing with a10m
only the first print, two colored dog from sd, was great
What slicer do you use?
I'm trying to print something with s3d 4.1.1
I can print with extruder 1, printing with extruder2 gives the error 104 wrong extruder, sometimes also error 109.
Same error appears if printing with both extruder.
is there a working s3d or cura setting?
3dralf wrote: Sun Jan 27, 2019 9:08 pm I have also many prob printing with a10m
The eg. gocde is creat by slic3r.
You can check it you can try to set the layer setting to 0.1mm+40mm/s print speed+4mm retract setting
Geeeko
Post by Geeeko »
I spent a lot of time with my A10M trying to print anything with two extruders and ending with big fails... Samples on the SD card worked fine tough. My mistake was to use Cura (3.6). I get some profiles on Thingverse or on this forum, added some Gcode found elsewhere, but nothing worked.
Hopefully I found this video:
https://www.youtube.com/watch?v=KJmEqgjjsGA
In description there is also a profile for Simplify3D and that one works fine for me.
